  • nexuz Friend
    #955368
    I have a problem with my background. On the home page, I can add a background. I have copied the theme for the other side and there would have a different background. When I select an image and only that particular part assigns the background but does not appear.
    What am I doing wrong?
    thanks Chris
    Hi there
    Backend account provided above doesn’t works , also could you provide more details about your problem describing step by step how to reproduce it ?
    nexuz Friend
    #955523
    Yes but it is not working properly. I have no idea what I’m doing wrong. I change codes in the custom.css or in the .less but not always, these changes become visible.
    I have made some changes to my layout. For that I have described in the video to activate the developer mode and the data in the. less changed. Then I less pressed to css and the developer mode disabled. Unfortunately, no change has been saved. Although I Duplicate a theme and memory appears not on the server. Am I doing something wrong? I would like my layout stored exactly as it looks in developer mode.
    So check again the login data.
    After you pressed compile less to css button all your files are moved below /local folder , best way to work in this way is to disable development mode and css optimization and work directly with custom.css file in this folder: /templates/JA_Social_II/local/css/themes/features/
    1. Screenshot-at-ago-01-12-25-17
    nexuz Friend
    #957477
    Hello
    how can I all changes in my layout I have changed to now save as custom.css? All changes are visible only when I have the Developer mode enabled. Once I disable these are lost all changes.
    Moreover, I fear that if I do an update from the template or joomla that all changes are overwritten.
    I have read the Dokumetation on your side but if I proceed according to these instructions will not work unfortunately.
    According to the documentation I have .less create in css. I press the button but the files are not saved. I disable the Developer mode, and my theme is very different. I activate Developer mode, all changes are available again and my theme looks like I should like to it.
    Many thanks for your help.
    Please take a look at the override section HERE
    It is better to look at what documentation says and test it yourself.
    This avoid confusion
    nexuz Friend
    #957610
    Hello
    yes i know but it dosnt work. why is my custom.css not loading? This is the first path what i try:
    /templates/ja_social_ii/local/css
    and i try this too:
    /templates/ja_social_ii/css
    But nothing work.
    Do you have n idear?
    Chris
    1) You should disable development mode from backend template management
    2) You are using a theme ( features) so your custom.css should go in /local/css/themes/features/ folder
    as you can see from images below custom.css file is correctly loaded on your website
    1. Screenshot-at-ago-07-18-16-09
    2. Screenshot-at-ago-07-18-16-39
This topic contains 7 replies, has 2 voices, and was last updated by  pavit 8 years, 4 months ago.
