  • dutton Friend
    #154753
    I am trying to use Web Links on our site however I need it to work and display with a bit more information.
    What I am seeking is how to display the date and order the links chronologically by the date. I understand all weblinks are time stamped when entered so I believe the above would be possible.
    gray Friend
    #357099
    in componentscom_weblinksmodelsweblink.php find the function
    [php]
    function _loadData()
    // Lets load the content if it doesn’t already exist
    if (empty($this->_data))
    $query = ‘SELECT w.*, cc.title AS category,’ .
    ‘ cc.published AS cat_pub, cc.access AS cat_access’.
    ‘ FROM #__weblinks AS w’ .
    ‘ LEFT JOIN #__categories AS cc ON cc.id = w.catid’ .
    ‘ WHERE w.id = ‘. (int) $this->_id;
    $this->_db->setQuery($query);
    $this->_data = $this->_db->loadObject();
    return (boolean) $this->_data;
    return true;
    [/php]
    try to add ORDER BY w.date DESC (more info)
    so it’ll be
    [php]
    ‘ WHERE w.id = ‘. (int) $this->_id .
    ‘ ORDER BY w.date DESC’;
    [/php]
    To add date into display layout you have to hack componentscom_weblinksviewscategorytmpldefault_items.php a little bit.
    dutton Friend
    #357119
    Thank you. I am not sure why but I am not seeing any changes at all.
    Last night I followed the instructions here and did not see any changes eiter.
    http://forum.joomla.org/viewtopic.php?f=431&p=2272998
    Any ideas?
This topic contains 3 replies, has 2 voices, and was last updated by  dutton 14 years, 2 months ago.
