  • Caleb Tseu Friend
    #136616
    Hi there,
    I had installed JA Vauxite and I found out that my web size is not fix as what I can view in the JA Vauxite demo page.
    If you go to my page – http://www.lifeandstyle.com.my/
    You can find that the right scroll bar can scrolling down further than the web size as the same for the bottom scroll bar.
    I found it same problem with IE and Firefox.
    How do I fix this problem – to make my page fit to browser ?
    Please advice.
    Calseven
    scotty Friend
    #284391
    Hi calseven, it looks to me like you have installed the template onto a Joomla install and the modules which should be published in the main content area are published to the left coloum.
    My advice is to start again and this time use the Quickstart option. Install Quickstart the exact same way you would a normal Joomla install and make sure to press the ‘install sample data’ button.
This topic contains 2 replies, has 2 voices, and was last updated by  scotty 16 years ago.
