andersonannem Friend
andersonannem
- November 2007
- 5 times in 1 posts
February 28, 2014 at 4:44 pm #195320Not exactly sure how to describe this.
Here is the link to the temporary site I’m building: *http://www.mycoachhome.com/WICustomHomesAvailableNow
I’ve noticed this on my mac using Safari, on my intel computer using IE8 and on my iPad. *I’m sure it would occur on my Android also.
Doesn’t happen on my smartphone because the slideshow, position-1 and 2 positions don’t show up on that platform.
When I use the JATabs in the right hand column or even if I’m using the Tabs & Slider module on the article on the home page, I need to scroll the site down to have the topmost links be clickable. *It’s as if there is something overlaying the space at least 1 inch below the bottom of the slideshow position and this is inhibiting the ability to click on any links.
I’ve included a screen shot below. *Can you see the lower edge of the black along the right hand side and then the position of the tabs on the JA Tabs module in sidebar-1? *At this position from the top of the screen, I cannot click on any of the tabs in the JA Tabs. *But if I scroll the page down, even a little bit, I can.
Any ideas?
andersonannem Friendandersonannem
- November 2007
February 28, 2014 at 7:29 pm #524808This is directly related to the changes I made to the script.js file and custom.css to fix the menu bar to the top (which I’d still like to do).
When I undid my changes and allow the menu to scroll off the page, the problem is gone.
Can anyone make any suggestions how I can fix the menu to the top and avoid this problem (see above).
Thank you.
Anne
MoonSailor FriendMoonSailor
- November 2011
- 248 times in 223 posts
March 3, 2014 at 8:22 am #525042<blockquote>Doesn’t happen on my smartphone because the slideshow, position-1 and 2 positions don’t show up on that platform.
</blockquote>You can go to administrator->templates manager -> JA Obelisk templates
Go to tab “Layout” -> “Responsive Layout” -> “mobile”, then you set to show it.By default, the template loads “slideshow” and “Slider” positions.
<blockquote>
“Can you see the lower edge of the black along the right hand side and then the position of the tabs on the JA Tabs module in sidebar-1? *At this position from the top of the screen, I cannot click on any of the tabs in the JA Tabs. *But if I scroll the page down, even a little bit, I can
</blockquote>I checked your site, it’s not JA Tabs plugin.
Please check again.
Viewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by MoonSailor 10 years, 6 months ago.
