  • gringo211985 Friend
    #189050
    Hi Guys,
    I have a problem with the JA Tabs and VM. Basically in the tabs you see a list of products and when you hover over the text of these products it turns blue. However when I updated a product the text has become dull grey and when you hover over it doesn’t turn blue. Take a look at pic below,
    How can I turn the text back to black and make it so when I hover the text turns blue?
    1. weird-VM-problem
    gringo211985 Friend
    #499456
    Just a little more info,
    I changed a products pricing from USD to GBP and then the product text in tabs turned dull grey, if I change it back to USD then it still remains dull grey.
    So it seems like every time I edit a product this happens, please can someone help me with a fix for this?
    Ninja Lead Moderator
    #499571
    Thanks for contacting us. In regards of your problem, please comply my following suggestion:
    + About problem of blue colour hover on text title product, i’m not sure of configging theme style from JA Hawkstore Template but you can set the configure as
    Go to Admin site -> Extensions-> Template Manager -> JA_Hawkstore – Blue color ->Assignment tabs -> click Toggle Selection appear all menu items with Blue style
    If you always show blue colour on visited of title
    Open templates/ja_hawkstore/css/themes/blue/vmsite-ltr.css file
    find and remove this script
    .vmgroup .vmproduct.productdetails .vmproduct-title:visited {
    color: #666
    + About products pricing from USD to GBP, you can use this way which will help you config USD to GBP, see the screenshot
    1. config_virtuemart
    gringo211985 Friend
    #500486
    <em>@Ninja Lead 381438 wrote:</em><blockquote>Thanks for contacting us. In regards of your problem, please comply my following suggestion:
    color: #666
    </blockquote>
    Hi Ninja,
    Thanks for the help, but it has not solved my problem. I have more information that might help give you a better idea of the problem.
    I want the title of the VM products to turn blue on hover, but when I edit and save any item in VM then the blue hover no longer works and the text turns dull grey. This is not good because every time I edit a product this happens.
    If you want you can take a look at my site but I have it offline mode atm so you would have to PM me and I will send user and pword to login.
    #500538
    Yes, please pm me URL of your site and admin access. I shall check it for you
    gringo211985 Friend
    #501049
    <em>@Ninja Lead 382685 wrote:</em><blockquote>Yes, please pm me URL of your site and admin access. I shall check it for you</blockquote>
    PM sent, thanks for looking into this for me Ninja
    #501109
    I fixed the problem on your site this way
    From
    color: #666;
    Change to
    color: #1e6590;
    Let me know if it helps
    gringo211985 Friend
    #501200
    Thanks for taking the time to solve this for me, it’s now working perfectly and once visited a link it does not dull out.
    Think this thread could help other people using this template, as I’m sure most will want the same result.
    Thanks again,
    Richard
This topic contains 8 replies, has 2 voices, and was last updated by  gringo211985 11 years, 5 months ago.
