Viewing 15 posts - 1 through 15 (of 18 total)
  • techvenue Friend
    #171499
    Hello All,
    I’ve gone through all the thread info about changing or eliminating “Welcome to Ja Rave” in the top of the Content-main area. Nothing matches up anymore :(( to answers in the forum. (FYI – Block Information = Content / Content-main )
    Have there been any changes in Rave since 2/2011? These suggestions don’t match up with my present day (11/2011) quickstart situation – I find no instances of this string “Welcome to Ja Rave” in any files (did full text search) and now wonder if it is in the sql database somehow?
    Please advise – my client is asking me what this thing is doing smack in the middle of the home page – thanks.
    n6rej Friend
    #428118
    <em>@techvenue 287183 wrote:</em><blockquote>Hello All,
    Please advise – my client is asking me what this thing is doing smack in the middle of the home page – thanks.</blockquote>
    go to the home menu, then advanced parameters and change the “page title”
    techvenue Friend
    #428133
    Hi There,
    Thank you for your reply. I was not sure what you meant by “home menu” – as this is in the middle of the page on top of the Content-main area and not a menu issue. It’s not the page title I’m concerned about, it’s just a little header that won’t go away.
    I’ve attached an image to give context.
    Thanks for any further advice.
    1. welcome
    we2solutions Friend
    #428135
    Hi techvenue.
    Please see this solution work.there is few other options but try if it works
    open file en-GB.tpl_ja_rave.ini
    found in “languageen-GB”
    and edit the Home Page Title.
    techvenue Friend
    #428246
    Thank you, but I believe this may not be the solution, even though it may have been in the past. Here is the entire text of that file ( en-GB.tpl_ja_rave.ini ) – it does not contain home page title verbiage or syntax. Again, this is a header *inside* of the page or template, not the title *of* the page. BTW: I still cannot find the “Welcome to Ja Rave” text in any system files. I downloaded my present setup and searched all files with nothing found. This is why I am wondering now if it’s in the SQL file? And how to discover and edit?
    ;_________________________Template-language___________________________;
    TOP=”Top”
    BACK_TO_TOP=”Back to top”
    MISSING_JAT3_FRAMEWORK_PLUGIN=”The plugin JAT3 framework must be installed and enabled.”
    TEMPLATE_DESCRIPTION=”JA Rave Template for Joomla! 1.6″
    MOBILE_VERSION=”Mobile Version”
    DESKTOP_VERSION=”Desktop Version”
    SWITCH_TO_STANDARD_MODE_CONFIRMATION=”Switch to standard mode? Switch back to mobile view via a link at the bottom of the page in standard mode”
    DO_NOT_SHOW_THIS_MESSAGE_AGAIN=”Do not show this message again”
    CLOSE_THIS_NOTICE=”Close this notice”
    IE6_WARNING_TITLE=”Did you know that your Internet Explorer 6 (IE6) is out of date?”
    IE6_WARNING_MESSAGE=”<p class=”_QQ_”note”_QQ_”>This template is compatible with IE6, however your experience will be enhanced with a newer browser.</p><p>To get the best possible experience using our website we recommend that you upgrade to a newer version or other web browser. A list of the most popular web browsers can be found below<p>”
    JACOM_CONTENT_CATEGORY=”In: %s”
    JACOM_CONTENT_WRITTEN_BY=”By %s”
    JACOM_CONTENT_ARTICLE_INFO=””
    DATE_FORMAT_LC_BUSINESS=”<span class=’date’>%d</span><span class=’month’>%b</span><span class=’year’>%Y</span>”
    _____
    Thank you for your continued advice my Joomla friends! 😀
    Phill Moderator
    #428264
    SImply go to the menu manager.
    Select “Main Menu”
    Select the “Home” item
    In the tabs on the right one will be called “Page Display Options”
    One of the boxes in there is marked “Page Heading” and contains the “Welcome to JA Rave” text. Change it to whatever you want and save the new setting. Clear your caches and you should see your new text.
    techvenue Friend
    #428269
    Hello Phill,
    Great solution – exactly right – it was related to the menu structure after all. My apologies for not cluing into that before :confused:
    Great solution – Thank You!
    Cheers,
    David
    <em>@phill luckhurst 287366 wrote:</em><blockquote>SImply go to the menu manager.
    Select “Main Menu”
    One of the boxes in there is marked “Page Heading” and contains the “Welcome to JA Rave” text. Change it to whatever you want and save the new setting. Clear your caches and you should see your new text.</blockquote>
    n6rej Friend
    #428408
    Select “Main Menu”
    Thanks Phill I should’ve been clearer
    cndglobal Friend
    #428513
    I have changed the text in this tab – Parameters (System) >Page Title
    it changes what appears in the top of the browser window but
    does not change the text “Welcome to Ja Rave” text which appears just below the slideshow.
    Am I missing something??
    cnd
    TomC Moderator
    #428515
    <em>@cndglobal 287691 wrote:</em><blockquote>From: Menus>Main Menu*>Home
    cnd</blockquote>
    Within Menus>Main Menu>Home>Page Display Options (Tab) . . .
    There should be two fields . . . “Browser Page Title” and “Page Heading”
    Try changing them both … making sure to save your changes and clear both your JAT3 cache (upper right of admin screen) as well as your browser cache … refresh page … and see if the changes take effect.
    cndglobal Friend
    #428551
    Thank you for your response but…….
    When I click on “Menus>Main Menu>Home>
    I do not see the: “Page Display Options (Tab) “
    My Home Page is set as “Front Page Blog Layout”
    I will attach the screenshot.
    Thanks,
    cnd
    1. home
    TomC Moderator
    #428552
    <em>@cndglobal 287744 wrote:</em><blockquote>Thank you for your response but…….
    I do not see the: “Page Display Options (Tab) ”
    </blockquote>
    Click –> Parameters (System)
    Phill Moderator
    #428555
    I think (though I am not 100% sure as I do not have the 1.5.x version installed at the moment) that you need to change this in the language file.
    Also, you need to update your Joomla install as 1.5.22 has a security issue.
    cndglobal Friend
    #428571
    I forgot to show the Parameters (System) in my screen shot but I only have “Page Title” there….
    If I have version 1.5.22 what upgrade version will give me the option I need to change the text “Welcome to Ja Rave” just below the slideshow.
    thanks
    cnd
    I’ll go back and click the Thank You Button:)
    1. parameters
    TomC Moderator
    #428583
    Glad to help.
    All the best with your continuing site development !!!
This topic contains 18 replies, has 6 voices, and was last updated by  TomC 13 years, 1 month ago.
