  • monimono Friend
    #188000
    hi
    we have to add rtl code.
    we did it like this: html .ja-mainnav……… in custom.css.
    is this the right way for doing it or there is a better way?
    thanks
    Hi monimono,
    If you want to customize template based on T3 framework, you can see this documentation for more info: http://t3-framework.org/documentation/customization.html
    monimono Friend
    #495014
    hi
    i visit the page http://t3-framework.org/documentatio…omization.html but there is no detail about rtl code only about custom.css so my question is: if i need to add rtl css code shuld i put it in custom.css.
    thanks
    Yes, the template will take precedence of style in this custom.css file and when update template, your customization will not be affected.
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 7 months ago.
