  • chizuoka Friend
    #197363
    if we compare the massheads here
    http://root.forwen.com/forwen/index.php/2014-05-03-10-32-40/rapidassign
    and
    http://root.forwen.com/forwen/index.php/2014-05-03-10-32-40/rapidassign-error
    The first link was modified from the included sample and the second was newly created. I have tried a lot of settings but i just cant get the text to be white with a bigger height. Where are these set?
    Thanks.
    TomC Moderator
    #533431
    Can you specify which text you are wanting to be white – perhaps with a screenshot capture and a pointer?
    chizuoka Friend
    #533444
    I am so sorry, i had sh404 put in so the links changed…. the page with white text
    http://root.forwen.com/forwen/mobile-apps/rapidassign.html
    The page without
    http://root.forwen.com/forwen/mobile-apps/rapidassign-error.html
    And the elements im mentioning about the mass head is this
    http://screenpresso.com/=5ZCVf
    TomC Moderator
    #533445
    Okay, here is what you can do . . .
    Create a file called “custom.css” within file path –> /templates/ja_beranis/css
    Put the following CSS rule within that file . . .
    h3 {
    color: #FFFFFF
    SAVE CHANGES – CLEAR CACHE – REFRESH PAGE
    Let me know if that works for you.
    chizuoka Friend
    #533448
    Oh? We are supposed use CSS to modify the formatting of the massheads? I thought just some lines in the masshead module and its done 😉
    How about the height?
    I also noticed that even i duplicated the mass head module to show an image… the image wont show either… i have to use CSS for that too?
    TomC Moderator
    #533451
    For the height issue, try this . . . . .
    Again, put the following within your custom.css file:
    .jamasshead h3.jamasshead-title {
    padding: 30px 0 0;
    .jamasshead.no-image {
    height: 110px;
    You can, of course, play around with the various pixel values until you arrive at the result you’re most happy with.
    chizuoka Friend
    #533457
    Hi.. please correct me if I’m wrong, but these seem to be global values and will affect ALL mass heads? What I am curious is why the example article included with the template works fine but when i create a new article following everything the same (to my knowledge) it will turn out differently, as you can see, non white text and small height.
    Am i missing something about the masshead configuration. I also noticed that Contact has a higher image, while the others have a smaller height image.
    goodpixel Friend
    #533462
    Hi, JA Masshead is a module with some configurations that you can modify page to page.
    For example, in case of Contact page, we have a module assigned to it, named ‘Contact Masshead’ that have a specific image linked to it with – like:
    [Masshead Itemid=”474″ title=”Contact Us” background=”images/joomlart/masshead/mh-1.jpg”][/Masshead]
    Also, Contact Module has specific alternative layout indicated in advanced tab (in module config)
    Please, note in your Module manager area that you have 4 different Masshead modules with different attibutes apllied – you can find usefull tips on how to use in module tab called ‘Description’ with fast and accessible descriptions and examples.
    Or you can visit this link to a longer tutorial: http://www.joomlart.com/documentation/joomla-templates/ja-beranis#install-extensions
    (search for section 4 – JA Masshead Module to find the tutorial)
    Let me know if this help!
    chizuoka Friend
    #533635
    I dont know what i did but it seems to be working erratically,
    If you see here
    http://root.forwen.com/forwen/mobile-apps/propeye.html
    http://screenpresso.com/=q9Kse
    Why would there be a duplicate black text below? but some others is fine… i think im missing something
    http://screenpresso.com/=KN5Ae
    Thanks…
    goodpixel Friend
    #533825
    Hi chizuoka, probably these pages have indicated the ‘page title’ mode ON
    You can edit this config in your specific article, AND in your main menu buttons of these pages
    EDITED: I look at your admin area, and problem in your case is that you have two JA Masshead modules indicated in that page, I only remove assignement of one of these modules, and black title is gone!
    Let me know if its all OK to you, and happy Joomlarting!
    chizuoka Friend
    #533834
    Oh stupid me.. thanks!
This topic contains 11 replies, has 3 voices, and was last updated by  chizuoka 10 years, 7 months ago.
