  • hearts Friend
    #125451
    Our site: http://www.hearts-at-home.net works in IE 6 without the ‘www’ but does not with the ‘www’: http://hearts-at-home.net . What would be causing this? Is there anyway to fix this?
    mj1256 Friend
    #238134
    did you set up your .htaccess redirect
    what is your path in your config file
    did you install any SEO components or activate seo in the config
    hearts Friend
    #238276
    <em>@mj1256 39173 wrote:</em><blockquote>did you set up your .htaccess redirect
    did you install any SEO components or activate seo in the config</blockquote>
    I didn’t set up a redirect. I set up http://www.hearts-at-home.net to point to my joomla site while testing.
    CONFIG FILE SAYS…
    $mosConfig_live_site = ‘http://hearts-at-home.net’;
    I didn’t set up any search engine optimization.
    hearts Friend
    #238280
    I just changed the config file to use the ‘www’ and now that works but without the ‘www’ when typed in as URL does not work. What do I need to do now?
    mj1256 Friend
    #238306
    change
    to
    $mosConfig_live_site = ‘http://www.hearts-at-home.net’;
    rename you htaccess.txt file to
    .htaccess (make sure you have the period first, no file extention)
    then add this line
    RewriteCond %{HTTP_HOST} ^hearts-at-home.net$ [NC]
    RewriteRule ^(.*)$ http://www.hearts-at-home.net/$1 [R=301,L]
    then you can go to the SEO tab on your Global Configuration and set it for yes
    now. for anyone else who reads this, this is an important step for all websites. If you don’t do this, google will see you as having two duplicate websites and penalize you in the rankings.
    this will redirect all requests fo the non www to the www domain and it should work now
    hearts Friend
    #238324
    When I changed the SEO tab all of my ‘right’ side menu links didn’t work but my top menu links did. I have switched the tab back to ‘no’ for SEO. Need to check in IE6 to see if it works.
    mj1256 Friend
    #238325
    yup, thats right, i’ve seen this before, you need to remove the right side links and remake them and they will work.
    you will find that the www and non www were in fact in conflict and you will need to redo some links.and maybe a module or two.
    this is not a browser compatibiliy issue
    hearts Friend
    #238394
    The re-direct does not appear to be working.
    Also, when I deleted the menu item and re-added it with the SEO ‘on’ the page was still not found.
    mj1256 Friend
    #238412
    i’m not a member of the staff, but I am willing to take a look for you
    could you pm me your login info and i will take a look later tonight
    your newsflash isn’t working, i may have a solution for that too!
    and…nice site 🙂
    hearts Friend
    #238616
    The newsflash only had one published item. It does work with two content items in there.
    I got the redirect to work through hosting cpanel redirect.
    Thank you for your help. The JA_Genista logo is still showing up with IE6 on mouse over but not happening in IE7. I’ve updated our logo in default and all colors. Where else might it be grabbing the default install logo from?
    mj1256 Friend
    #238641
    I had the same issue, they kept getting cached somewhere
    I finally gave them new file names and changed the paths to the logos in the CSS and that solved it for me
This topic contains 11 replies, has 2 voices, and was last updated by  mj1256 16 years, 10 months ago.
