  • amit_s_r Friend
    #170632
    My website url is http://www.freeaffiliateassistant.com/
    Joomla version is 1.5
    And the theme is JA Events.
    For login goto members area,whenever i login as admin and go for member management(A particular tab which have access level “special”) it will say you must first login instead i am already login this scenario would occur when i am not click on remeber me,If I have click on remeber me it works fine…
    I am attaching the screenshot so you could easily unstand ..
    Thank you.
    1. instead-of-login-it-showing-pls-login
    kobenes Friend
    #424342
    Please clear your Cache and JAT3 cache… Also go to Tools > Global Check-in (for Joomla 1.7: Site > Maintenance > Global Check-in)
    amit_s_r Friend
    #424524
    Thanks for your response,I have clear Cache but still have the same problem….
This topic contains 3 replies, has 2 voices, and was last updated by  amit_s_r 13 years, 1 month ago.
