  • hamlethub Friend
    #163340
    We are switching to the JCE Editor from Tiny MCE.
    We are using Joomla 1.6 and Teline IV.
    When we use JCE editor to add an image, it does not appear on the front page. However, the image is still part of the article.
    If we add the image using the Tiny editor, it works fine, and a thumbnail appears on the front page.
    do you know if this is a compression issue, or some setting in JCE, or in the template?
    hamlethub Friend
    #389077
    Thank you very much. But can you tell me what files I need to put in there? Is it just the three files in your example, or all of the files that user Pepperstreet has listed?
    Phill Moderator
    #389080
    Try just the three, it is working on my local install.
This topic contains 4 replies, has 3 voices, and was last updated by  Phill 13 years, 8 months ago.
