  • mandrews Friend
    #132889
    In the Joomla 1.5 Mesolite Position dropdown menu, there is no entry for a “slideshow” position. Your tutorial says that I should select this position for the “slideshow” module. Please advise.
    Thanks,
    Mark Andrews
    Menalto Friend
    #268432
    You can open up the templateDetails.xml and find this here:
    <position>debug</position>
    </positions>
    And add this:
    <position>slideshow</position>
    above
    </positions>
    Remember to save.
    Or you can simply just type in the module positions name in the field where you have the names.
This topic contains 2 replies, has 2 voices, and was last updated by  Menalto 16 years, 3 months ago.
