  • tzic Friend
    #208793
    Hello I am trying to add facebook modules and they require that I put some scripts after the body tag. Can you please tell in which file I should put the scripts? I am using purity II on joomla 2.5
    You can add scripts into this file templatesja_purityiitplsblockshead.php
    tzic Friend
    #577541
    Thank you @pavit you helped me alot. Actually it was located in templatesja_purityiiblockshead.php There is no tpls folder in my setup
    <em>@tzic 483125 wrote:</em><blockquote>Thank you @pavit you helped me alot. Actually it was located in templatesja_purityiiblockshead.php There is no tpls folder in my setup</blockquote>
    Ok my bad , it is working now ?
    tzic Friend
    #577545
    <em>@pavit 483126 wrote:</em><blockquote>Ok my bad , it is working now ?</blockquote>
    Yes it does as it should. Do you know if there is an easy way to can make ja purity 2 responsive for the new google algorithms, or I should go for ja purity 3?
    This is the best way to obtain it. no way to make purity II responsive
This topic contains 6 replies, has 2 voices, and was last updated by  pavit 9 years, 5 months ago.
