February 25, 2014 at 8:55 am #195185
After template installation I have white frame on home page. How can I fix that?Also, there is a problem with content JA Bookmark plug in. Installation is successful, but when I want to set parameters in plug-in, just one part of the set-up page is loading with the message Error: 0 SQL=SELECT m.* FROM i05dy_k2_categories m WHERE trash = 0 ORDER BY parent, ordering:
Third problem is pop up window – it doesn’t work. I don’t need that feature at the moment, but I would like to know how to solve it.
website is http://www.mgstudio.com.au
Saguaros ModeratorSaguaros
February 26, 2014 at 8:06 am #524418I see the home page of your website is working fine now, have you sorted it out?
With the issue of JA Bookmark plugin, the error seems to relate to K2 content. If you don’t install K2 component on your site, please don’t enable any option in this plugin for K2 content.
For the 3rd problem, you can PM me admin and FTP credentials of your website, I need to debug further.
February 26, 2014 at 12:16 pm #524460Thank you for help!
I solved second issue. Plug-in for Xmap K2 was enabled….
Home page is working fine but there is still white frame around featured articles in home1 position. I would like to turn that of if it’s possible.
Do you have any idea how to do that?
Thanks!Saguaros ModeratorSaguaros
February 27, 2014 at 4:23 am #524562Thanks for help!
Upper part of white frame is gone. Can we try to cut it on the left and right side?
What code should I add?Check it on http://www.mgstudio.com.au
February 27, 2014 at 10:43 am #524618Yeah, but frame is black now, it’s still exist. Articles are not in the same line with logo and footer….. is there any solution for that?
This topic contains 9 replies, has 2 voices, and was last updated by miroslavg 10 years, 8 months ago.
