  • jonatha2 Friend
    #185699
    Hello
    I run the Linlithgow Folk Festival Association website. The domain name is http://www.linlithgowfolk.com
    When viewed with the www. part it loads and views absolutely fine. However, when viewed by typing in linlithgowfolk.com (without the www.) it moves the menu text to a larger different font and this results in it moving down a line.
    This shouldnt happen. Can anyone advise why this is happening and what the solution is?
    Jonathan
    Luna Garden Moderator
    #485999
    Hello Jonathan,
    Please try this:
    Go to this file:
    ja_tirisfontsabelstylesheet.css
    Change these lines:
    @font-face {
    font-family: 'abelregular';
    src: url('abel-regular-webfont.eot');
    src: url('abel-regular-webfont.eot?#iefix') format('embedded-opentype'),
    url('abel-regular-webfont.woff') format('woff'),
    url('abel-regular-webfont.ttf') format('truetype'),
    url('abel-regular-webfont.svg#abelregular') format('svg');
    font-weight: normal;
    font-style: normal;
    to
    @font-face {
    src: local('fonts/abel'),
    font-style: normal;
    Hope this helps
    jonatha2 Friend
    #486392
    Hello
    Thanks for this information. However, upon checking, the above instructions sort the problem when viewing the site as http://linlithgowfolk.com
    Though it results in http://www.linlithgowfolk.com showing the white bar problem.
    I have reset it back to what it originally was like. Can you indicate what the solution may be ?
    Jonathan
    #486417
    <em>@jonatha2 364349 wrote:</em><blockquote>Can you indicate what the solution may be ?
    </blockquote>
    Hi Jonathan,
    The problem is from Firefox default font policy, this template use font-face, but Firefox does not allow cross-domain fonts by default (even with sub-domains).
    For example, if you’re viewing this page:
    http://example.com/about
    and the fonts are being served via CSS from:
    http://www.example.com/templates/folder_template/css/templates.css
    You can follow some solution here may help you out:
    http://stackoverflow.com/questions/2892691/font-face-fonts-only-work-on-their-own-domain
    http://stackoverflow.com/questions/5008944/how-to-add-an-access-control-allow-origin-header
This topic contains 4 replies, has 2 voices, and was last updated by  Luna Garden 11 years, 9 months ago.
