  • artij Friend
    #942765
    Hello, I’m configuring ja wall and I have an issue. No matter which template style I choose, top menu shows as white box. Please help.
    Regards, Artur
    1. ja
    Hi Artur,
    You can send me the Admin login info of your site so I will have a look.
    artij Friend
    #943158
    artij Friend
    #943979
    Any idea?
    Something wrong here, could you also send me the ftp account so I can have a closer look at code?
    artij Friend
    #945269
    artij Friend
    #946657
    Hi Artur,
    It’s working now.
    The reason is that you changed the module style of this menu module under Advanced tab in backend settings. I revert the change and it displays fine now.
    artij Friend
    #946855
    Hi Saguaros,
    Yes it is now working perfect, thank you for help!
    Regards,
    Artur
    You’re welcome!!!
This topic contains 10 replies, has 2 voices, and was last updated by  Saguaros 8 years, 5 months ago.
