  • turminator Friend
    #176756
    I see that my JA Norite not have same format than Norite DEMO. And it showing the litte size image logo.
    Many thanks.
    http://www.barcelonacreations.com
    In order to have an exact copy of the demo site on your server, you need to install the quickstart version of the template
    Try to look here for a guide on the quickstart installation
    turminator Friend
    #451674
    Hello pavit,
    Thank you for your reply. I don’t want an exactly copy of demo site. I only want that the page that I selected will be frontpage have got the logo.png image with the large size. Now all pages have got the small size.
    Many thanks!
    1. norite
    You need to check in this file templates/ja_norite/css/template.css around line 880
    .ja-home h1.logo a {
    background: url("../images/logo.png") no-repeat scroll left center transparent !important;
    height: 80px;
    width: 318px;
    and insert your logo.png image 318 x 80 in the folder templates/ja_norite/images
    turminator Friend
    #451676
    Hello Pavit,
    Thank you for your support.
    I verify it and it’s all correct but it continues not showing the frontpage logo.png format. i do not do any change in template.
    Many thanks!
    Could you send me via PM your super user details i will check your files
    turminator Friend
    #451678
    Hi pavit,
    I sent data access details.
    Many thanks.
    I have changed your home item type from single article to featured articles as is in the demo site and now your page shows correectly the second larger logo image
    turminator Friend
    #451696
    Hello pavit.
    Now it looks perfectly.
    Many thanks for your help.
This topic contains 9 replies, has 2 voices, and was last updated by  turminator 12 years, 6 months ago.
