  • virakamrith Friend
    #196340
    Why script and CSS in my template store on Body? Its usually its store in Head not body.
    TomC Moderator
    #529027
    Is there a particular issue/problem this is causing?
    Which script / CSS did you refer to? I tried to view source code of your site, it seems to locate in the header of your site.
    virakamrith Friend
    TomC Moderator
    #529810
This topic contains 5 replies, has 3 voices, and was last updated by  TomC 10 years, 9 months ago.
