  • hotsd101 Friend
    #183240
    how can change
    ja-right width from 33% to 20%
    and
    ja-mainbody from 67% to 80%
    cannot find this anywhere.
    assist plz urgent.
    hotsd101 Friend
    #476796
    no answer here ? i check k everywhere cannot find this
    Ninja Lead Moderator
    #476880
    You can do that with this way
    <blockquote>Admin -> Extensions->Template Manager->JA_Mendozite – Default->Layouts Tabs->Edit Default</blockquote>
    from
    <blocks name="middle" colwidth="33">
    <block name="right1">left</block>
    <block name="right2" width="25">right</block>
    </blocks>
    change to
    <blocks name="middle" colwidth="20">
    <block name="right2" width="20">right</block>
    </blocks>
    Remember to clear JAT3 cache from admin
    hotsd101 Friend
    #476884
    ok thank you.
    BUT when when i change this, the right side no longer the modules adjust to fit automatically. what is need to be change so when right side is 20% the modules in it also fit automaticlly at 20% ?
    thanks you
    hotsd101 Friend
    #476930
    I try everything but cannot find.
    #477038
    Please pm me with url and admin access on your site, i shall help you out of it
    hotsd101 Friend
    #477081
    send pm u with details mr.
    please assit as having problme for lots of it
    #477105
    You configured ja-right postion that’s right but you need to change css file as my suggestion
    <blockquote>templates/ja_mendozite/css/layout.css</blockquote>
    from
    .main .inner {
    /* We use liquid layout, so we need to insert a div which will create margin if need */
    padding-left: 30px;
    padding-right: 30px;
    change to
    .main .inner {
    padding-left: 10px;
    padding-right: 10px;
    The problem ja-right postion fixed it, please check it again.
    hotsd101 Friend
    #477107
    this is all u chaage or also something else ?
    #477164
    <em>@hotsd101 351707 wrote:</em><blockquote>this is all u chaage or also something else ?</blockquote>
    I have fixed width=240px on facebook like, virtuemart search from on ja-right position. You can use Firebug – addon of FireFox to check on this.
This topic contains 10 replies, has 2 voices, and was last updated by  Ninja Lead 12 years ago.
