October 29, 2012 at 8:47 pm #181800
Beautifull themplate.
Question: The mainmenu on the hornav position is always 100% width of your browser. Is it possible too give the mainmenu the same width as the header and main body?Ninja Lead ModeratorNinja Lead
- November 2014
- 3854 times in 3563 posts
November 1, 2012 at 4:20 am #471633yep, you can do this.
<blockquote>Admin area->Extensions->Template Manager->JA Purity II – Default->Layout tabs->Edit Default</blockquote>
Findmain-inner="1"
and replace tono-main="1"
Example:
<block name="mainnav" type="mainnav" main-inner="1"></block>
Replace to<block name="mainnav" type="mainnav" no-main="1"></block>
November 3, 2012 at 3:30 pm #471835Thanks for the quick reply. I tried it, unfortunately the result is not what I was hoping for. Probably I used the wrong words/terms to describe my problem.
In the attached picture, from localhost, you can see the white space between header and ja-main. Is it possible too give it the same with as “main” and “main clearfix” so the blue border also outside the mainnav.
Thanks in advance.
- November 2014
November 5, 2012 at 3:51 am #471889Your error is weird, this is the first time I face, may be i need to check it on livesite. Please send me URL, admin access, i will check it.
- November 2014
November 7, 2012 at 10:48 am #472154I found the problem on your site.
<blockquote>Open templates/ja_purity_ii/css/template.css file</blockquote>
you find and see this script
#ja-container {
background: url(../images/container-bg.gif) repeat-x top #fff
position: relative;
z-index: 5;
border-bottom: 5px solid #ccc
Here is link: <blockquote>http://www.euro-pac.eu/templates/ja_purity_ii_europac/images/container-bg.gif</blockquote>
You can remove this link background or change it with other background1 user says Thank You to Ninja Lead for this useful post
November 7, 2012 at 3:35 pm #472177Thanks for looking. I know that I can edit the container-gb.gif but the problem is that is over the full with op my webpage. I am trying too get borders at the left and right side of my whole page.
When typing this I had an idea 😉 and changed the body#bd #ja-wrapper too this (red is new):
body#bd #ja-wrapper {
background-color:#143575;
overflow:hidden;
padding:0 15%;and this was what I was looking for.
Thank you for you’re help.
November 7, 2012 at 4:31 pm #472185The alteration like I mentioned above I did that with firebug but that’s only temporally. Now I am looking for the right css file in the template directory which contains “body#bd #ja-wrapper”. Unfortunately I can’t find the file :-[. I think it is in the t3-assets folder. Is there an other solution of css file edit to achieve the same goal?
- November 2014
AuthorPostsViewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by Ninja Lead 12 years ago.
Width hornav same as body and header
