Pankaj Sharma Moderator
August 22, 2017 at 1:12 am #1057773Hi
Do you have any custom module positions?
Can u share more details in a screenshot and let me know what issue you are facing?
I checked above page and it look like you have custom work in the mainbody php file.Regards
timpennington Friendtimpennington
- May 2009
August 22, 2017 at 2:24 am #1057794Here are two screenshots; the position home-2 is going under the sidebar-1 area
August 22, 2017 at 2:36 am #1057801Hi
You have to define the style classes in your module position code.
At this time its using full width.
Add class col-md-9 so it will use the same space as the main body container.
Or you can remove the container class from the module position code to get the same width as the main body.Regards
- May 2009
August 22, 2017 at 12:02 pm #1057932Can you suggest how to do that?
What the coding would be, and what file to insert it in?
Thank you for the help
August 23, 2017 at 1:24 am #1058014Hi
The path of the file is template folder/tpls/blocks/mainbody.php
On your site, its customised file and there are new module position added by you on this file.
Just remove the container class from these module positions.Regards
- May 2009
August 23, 2017 at 2:55 am #1058051This is what I have:
<?php if ($this->countModules(‘home-2’)) : ?>
<div class="wrap <?php $this->_c(‘home-2’) ?>">
<div class="container">
<jdoc:include type="modules" name="<?php $this->_p(‘home-2’) ?>" style="raw" /><?php endif ?>
So what gets removed??
August 23, 2017 at 3:10 am #1058054Just remove the container class from these module positions.
container
- May 2009
August 23, 2017 at 11:16 am #1058147Do I just remove this:
<div class="container">Or do I remove both of these:
<jdoc:include type="modules" name="<?php $this->_p(‘home-2’) ?>" style="raw" />Thank you
- May 2009
August 23, 2017 at 3:03 pm #1058198If I remove this line:
<div class="container">Then the sidebar-1 on the right disappears
<jdoc:include type="modules" name="<?php $this->_p(‘home-2’) ?>" style="raw" />It removes the home-2 block altogether
If I remove both lines:
So can you be specific in what lines to remove?
Here is what I have, and could you tell me what it should be?
<?php if ($this->countModules('home-3')) : ?> <div class="wrap <?php $this->_c('home-3') ?>"> <div class="container"> <jdoc:include type="modules" name="<?php $this->_p('home-3') ?>" style="raw" /> </div> </div> <?php endif ?>
- May 2009
August 23, 2017 at 4:03 pm #1058206Thank you; I removed the word "container"
Sorry if that wasn’t clear to me
Viewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 2 voices, and was last updated by timpennington 7 years ago.
The topic ‘Width of Home-2 module block position’ is closed to new replies.
