August 25, 2011 at 2:42 am #167764
hi there,
i finally set up ja travel template. and now i face a problem.
i use a specified width for the template, and when i try to change the profile to another color, it works fine on joomla pages, but pages that use jReviews plugin do not expand to specified width – instead they stay the same width as before.
what can be done
take a look at the site
homepage – http://tirereviewer.com
sample jreviews page with unchanged width – http://tirereviewer.com/tires/general-altimax-hp
cyprusmedya Friendcyprusmedya
- May 2011
- 15 times in 14 posts
August 25, 2011 at 3:08 am #408276which browser are you using? i looked at your site with google chrome and both pages index and item page were at same width
August 25, 2011 at 4:10 am #408286hi there,
problem seems to persist only in IE7 and IE8.
what can be done?
- May 2011
August 25, 2011 at 4:23 am #408291Hello Serega you don’t need to create multiple posts, simply reply this post okay? i merged your two threads to prevent confusion. let me to have a look at your site and will tell you how to solve it.
August 25, 2011 at 5:23 am #408301hey,
thanks for the reply. i did not create 2 threads, its just the forum was lagging, so i tried multiple times to post my question. i guess it double posted it.
yes, the problem is only visible in IE. and though we all hope that nobody uses IE anymore, it is still something i d like to get fixed.
thx for your help (or at least an attempt) 🙂
- May 2011
August 26, 2011 at 6:19 am #408652please give me your back-end login details so i can check the template settings please?
August 29, 2011 at 6:35 pm #409445how do i give u my admin info? (dont see any private message option)
i tried every possible variation – it does not matter. if you take a look at the site, you see that specified width with colored theme works fine in IE only on pages that do not use other extentions. so basic joomla pages like joomla articles work fine, but when you try jreviews listing, or kunena forum page – thats where specified width is not working.
i think its a compatibility issue on your side. i would love some more input into this issue from other mods as well – its a serious problem that needs to be fixed asap.
thanks.
- May 2011
August 29, 2011 at 6:41 pm #409446we will check it okay, simply click on my user name and a menu will be opened, click on to private message to give me your back-end details.
August 29, 2011 at 7:20 pm #409452sent it
please confirm u got it
- May 2011
August 29, 2011 at 7:33 pm #409455okay got it, checking now.
- May 2011
August 29, 2011 at 8:22 pm #409476check your pm inbox please i sent your a pm with some details.
August 29, 2011 at 8:53 pm #409487did that, no results. check your pm.
August 31, 2011 at 6:18 pm #409898any hope for solution? or things you cant solve you just leave hanging in the air? 🙂
September 9, 2011 at 7:08 am #411654amazing support guys – absolutely love it! left my issues hanging without a response, no solution, no advice, not even a bit of hope – thats the spirit! appreciate that very much indeed. cant wait to renew my membership!!!!!
hey guys, thanks again!
This topic contains 25 replies, has 5 voices, and was last updated by TomC 13 years, 3 months ago.
