  • hoskic Friend
    #118881
    Installing Xenia template went very nice and smooth but problem is when headline module is displaying atricles in different encoding, like for me i am using croatian letters and everything is messed up. I tried to change encoding in file mod_janews.xml or in tepmplatedetails.xml file but still the same. This module is looking good only for english letters.First article in headline module is showing fine with all croatian letters but when slideshow starts every croatian letter is messed up. On all other places in template everything is fine except in headline module…please some advice:confused:
    ha le-viet Developer
    #214813
    Hi hoskic,
    At this time JA News module doesn’t support CP-1250 charset. There will be a solution if your host enable iconv module, but I’m afraid not many host support it.
    The next version will support all charset but you will have iconv module installed on your PHP. You can ask your hosting provider for more information.
    Regards,
    Ha Le-Viet.
    plastikkboy Friend
    #215270
    i have the same problem. i need cp-1251 support. what must i my hosting provider asking?
    my phpinfo: ‘./configure’ ‘–enable-pic’ ‘–prefix=/usr’ ‘–with-xml’ ‘–enable-bcmath’ ‘–enable-calendar’ ‘–with-curl’ ‘–with-dom’ ‘–with-dom-xslt’ ‘–with-dom-exslt’ ‘–enable-exif’ ‘–enable-ftp’ ‘–with-gd’ ‘–with-jpeg-dir=/usr/local’ ‘–with-png-dir=/usr’ ‘–with-xpm-dir=/usr/X11R6’ ‘–with-gettext’ ‘–with-iconv’ ‘–with-imap’ ‘–with-imap-ssl’ ‘–with-kerberos’ ‘–enable-mbstring’ ‘–enable-mbstr-enc-trans’ ‘–enable-mbregex’ ‘–with-mcrypt’ ‘–with-mhash’ ‘–enable-magic-quotes’ ‘–with-mysqli’ ‘–with-mysql=/usr’ ‘–with-openssl’ ‘–enable-discard-path’ ‘–with-pdflib’ ‘–with-pear’ ‘–with-pgsql=/usr’ ‘–enable-xslt’ ‘–with-xslt-sablot’ ‘–enable-sockets’ ‘–enable-track-vars’ ‘–with-ttf’ ‘–with-freetype-dir=/usr’ ‘–enable-gd-native-ttf’ ‘–enable-versioning’ ‘–enable-wddx’ ‘–with-xmlrpc’ ‘–with-zip’ ‘–with-zlib’
    #215274
    Hi plastikkboy,
    iconv library is enough. Upgrade to the latest version and you’ll see the change.
    Regards,
    Ha Le-Viet.
This topic contains 4 replies, has 3 voices, and was last updated by  ha le-viet 17 years, 9 months ago.
