  • maikd Friend
    #130766
    Hello all,
    I have installed Xenia II and all will work well (Joomla 1.5.3).
    After installing the New Jommla Forms component from Phil Taylor, the following error occurs:
    Fatal error: Call to a member function setQuery() on a non-object in /home/xxxxxxx/public_html/templates/ja_xenia_ii/ja_menus/Base.class.php on line 45
    I have traced the error back to the xajax component.
    Is Xenia II not compatible with xajax?
    Thanks in advance,
    mike
    #259625
    Hi maikd !
    You try to do following wayy below :
    – Download base.class.zip file then extract it
    – Copy and overwrite to templatesja_xenia_iija_menus folder
    Note : don’t forget backup old file.
This topic contains 2 replies, has 2 voices, and was last updated by  Sherlock 16 years, 5 months ago.
