  • ebajh69 Friend
    #146499
    I am trying to use Joomla Forms with JA-Kyanite ii. When I use the date picker option on my form, the Calendar doesn’t display.
    According to the developer:
    <blockquote>
    It is showing – but behind your white box page inner. You need to check your sites templates CSS file and remove the z-index entries until it works. If you change the the default Joomla template you will see that I’m right.</blockquote>
    Before I remove the entries, I was wondering if there was a better fix. :confused:
    Also, is z-index used for anything? I don’t want to fix one issue and create some others.
    I removed:
    z-index: 5
    From Line 762
    #ja-container {
    position: relative;
    padding: 10px 0;
    z-index: 5;
    So that it looks like this
    #ja-container {
    position: relative;
    padding: 10px 0;
    The calendar displays, not sure what side effects this will have.
    Thanks,
    Evan
    mihirc Friend
    #325466
    Removing a z-index is not such a great idea. What I can suggest is that, you open your css file that refers to the calender and give it a higher z-index number. For example, in your case of the ja-container has z-index file, then give the form a z-index of 20. And dont forget to put in the position piece as well. Both of them go hand in hand.
    FORM{
    z-index:20;
    position: relative;
    … other css;
    Regards.
    Mihir Chhatre.
This topic contains 2 replies, has 2 voices, and was last updated by  mihirc 15 years ago.
