  • websquirrel Friend
    #1090113
    Hi, I experience a z-index issue that causes conflicts between your module and menues. The markers of your module cover all menu item of my website. See screenshot. This is not beautiful, having markers from image map overlapping submenu items. I checked z-index numbers and found out that your stylesheet seems to set z-index of your markers and popups to 999! Why that high? Do you intend to cover every menu out there? Do you know any menu with higher z-index than 999? I do not. However, where can I reduce that z-index for your module and its’ elements?
    1. Bildschirmfoto-2018-02-05-um-11.18.06
    Pankaj Sharma Moderator
    #1090231
    Kindly share the URL of page, So that i can check this issue on your site.
    websquirrel Friend
    #1090332
    #1090499
    The issue is not from module it’s from your template menu z-index issue.
    you can reduce the z-index of the module by adding this code to your template.css file
    add the code at the end of file
    .jai-map-container {
        z-index: 990;
    Save file, clear cache and check.
This topic contains 3 replies, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 10 months ago.
