  • surdo Friend
    #805870
    can’t seem to edit my post…. the first sentence should read:
    On my site, all pages using K2 experience z-index issues.
    surdo Friend
    #808399
    I found a partial fix for this, which was to "disable" the sliding header by giving it the position "absolute", for example:
    @media (min-width: 992px) {
    .t3-header-wrap.affix {
    top: 0;
    z-index: 1030;
    position: absolute;
    .t3-header-wrap.affix .t3-header {
    background: rgba(0, 0, 0, 0.86) none repeat scroll 0 0;
    padding-bottom: 0;
    padding-top: 0;
    I think I prefer this to the default scrolling header as it gives the page more space. Now when the user scrolls slowly down on a page such as: http://escuta.org/info.html, the header first darkens before disappearing. This is quite a nice effect, however I’d like to know how this transparent overlay can be removed all together. I wasn’t able to work out how to remove it.
    Thank you
    surdo Friend
    #810145
    Just in case my question wasn’t clear: I’d like to know how the header’s transparent overlay can be removed all together? The overlay that appears when the user begins to scroll the page. For example, on this page: http://escuta.org/projetos/instalacao/sv/intro.html
    Try to increase the z-index value of t3-header-wrap.affix from 1030 to 9999
    z-index:9999;
    surdo Friend
    #810469
    Thanks Pavit. I don’t know how I missed that. I’ve been working on this for too long!
    One great improvement to the menu, would be to implement the following:
    When the user scrolls towards the bottom of the page, the menu overlay disappears. However when the user scrolls towards the top, the overlay (with navigation) reappears. This would give a lot more space on small screens when a user is reading down the page.
    Is there a way of doing this?
    Thanks for your help
    Hi @surdo
    You can submit this request under the specific forum HERE
    Best regards
This topic contains 6 replies, has 2 voices, and was last updated by  pavit 9 years ago.
The topic ‘z-index problem’ is closed to new replies.
