November 3, 2008 at 2:51 pm #135040
Hi all,
I am working with JA_Sanidine II and i have a little problem with the Pixsearch component.
I have published Pixsearch in user4 position and the results are behind the white background in IE7 (it works with Firefox). I tried to play with the z-index without success (z-index for the results=10000, z-index for #ja-header=999).
I made some screenshots.
How to resolve that plz ?
Sherlock
- 2478 times in 2162 posts
November 4, 2008 at 6:41 am #277991Can you give us your live URL?
November 4, 2008 at 8:30 am #278008Hi,
I just setup a temporary site for you: http://joomlatest.hiezone.comThe search results are well displayed with Firefox. With IE the top of the box is behind the header-bg
Thanks for the help
GuillaumeSherlock FriendSherlock
November 4, 2008 at 8:37 am #278009Hi
Seem I miss your question, in this template, doesn’t have user4 position and I can’t see PixsearchPlease say more detail or send link where has that error
November 4, 2008 at 9:02 am #278013Hi,
This template has an user4 position (top-right). Pixsearch is coming as an alternative to the traditional search module. Pixsearch is active at the moment. If you type a search in IE you will see that the results are behing the header. In Firefox all is Ok
Thanks in advance
November 4, 2008 at 9:07 am #278016Hi
you can view http://joomlatest.hiezone.com/?tp=1, you will see all position of templateI searched on IE and evrything is fine
November 4, 2008 at 9:28 am #278022I must not understand something. Can you confirm that:
1) there is a module published in the user4 position for the http://joomlatest.hiezone.com site ?
2) that this module is a search module (Pixsearch)
3) that in IE7 when you type lets say “fron” (without pressing Enter) in the searchbox the top of the box is not beyond the header ?
Cause for me it does not work like it should do (tested with 2 computers under Vista/IE7). In Firefox 2.0 all is OK
Thanks again for your help
GuillaumeNovember 5, 2008 at 7:50 am #278130Nobody can help me on that ?
Thanks -
Viewing 8 posts - 1 through 8 (of 8 total)This topic contains 8 replies, has 2 voices, and was last updated by guillaume14 16 years ago.
