  • Dalibor Bosnjakovic Friend
    #143670
    Hi, i have a problem with z index in a submenu. You can see it on this link:
    live site
    The problem is with te one before last one. The submenu drops behind the flash in topsl2 posititon. I hav tried to put z-index in css but i am not sure if i have done that the right way because it is not helping.
    Can anyone help me please?
    Thanks. Dalibor.
    Hello dbosnj35!
    I have answered in the JA Support Department, We both discuss together, ok ? 🙂 I give you the solutions to resolve this problem.
    You add this code section inside OBJECT Tag “<param name=”wmode” value=”transparent”>
    Your Flash Code:
    [PHP]
    <object width=”246″ height=”262″ type=”application/x-shockwave-flash” data=”images/stories/logo.swf”>
    <param value=”/images/stories/logo.swf” name=”src”/>
    </object>
    [/PHP]
    >>> you change:
    [PHP]
    <object width=”246″ height=”262″ data=”images/stories/logo.swf” type=”application/x-shockwave-flash”>
    <param name=”src” value=”/images/stories/logo.swf”/>
    </object>
    [/PHP]
    I make sure it work perfect 🙂
    Good luck
    #315193
    I have made mistake and stated that the best answer is mine instead of yours, sorry. Can admin change this??
This topic contains 3 replies, has 2 voices, and was last updated by  Dalibor Bosnjakovic 15 years, 4 months ago.
