  • pixelstext Friend
    #138762
    i’m using ZinC Graffiti and Joomla 1.5.9
    live url = http://www.depoolster-elsloo.nl
    i checked this site in Firefox 3.0.0 + IE 7.0 + Google Chrome 1.0.154.48 + Opera 9.63 everything seems okay. But unfortunately my customer uses IE 6 and then there is a problem. Behind the regular background (content-center.gif) appears a white field.
    Screenshot at : http://www.depoolster-elsloo.nl/cms/templates/bg_fail.jpg
    Does anybody know this problem and how to fix it?
    Thanks (and sorry for old-school English…)
    jwellman Friend
    #294416
    It’s been a long week. Deleted my post after realizing my answer will not help you in the least. 😀 sorry.
    This is the image that is probably giving you trouble in IE: content-center.png Have you changed all the images is your Graffiti IE6 folder to .gifs? IE 6 will not recognize .png’s.
    flicman Friend
    #301718
    this is definitely to do with your settings in the /#template/css/colors folder in the graffiti-ie6.php file. I’d guess that you have a bg .gif set to repeat across all 950px of the center background.
    I don’t know for sure because this seems to be the way that it ships, but make sure you have a line in your graffiti-ie6.php file that looks like this:
    #ja-container {
    background: url(../../images/graffiti/content-center.gif) repeat-y center top;
    It’s going to be related to that piece of code, I think. I’m a little paranoid now, though, because I seem to remember another bit of code from yesterday that I can’t dredge up. If I find it, I’ll be back.
This topic contains 3 replies, has 3 voices, and was last updated by  flicman 15 years, 9 months ago.
