  • azot94 Friend
    #189476
    HI,
    ZOO does not work with JA T3 Framework. When JA T3 Framework is on I haven’t access to the pages of Zoo. http://jadrowe.pl/zoo
    phong nam Friend
    #501355
    Hi azot94,
    Can you try to check out the SEF urls configurations on your website ? The front-end and backend of my T3v2 template (Blank template) site still worked fine when the Zoo plugin was enabled on both my localhost and demo hosting.
    azot94 Friend
    #501418
    Thanks for your reply 🙂
    I checked SEF configuration and it is ok. I found the solution to the problem Template “JA NEX” ver. 2.5.7 does not work with component ZOO ver 3.0.13. What a pity!
    phong nam Friend
    #501421
    Hi azot94,
    Can I know your solution on this concern ? It will be really appreciated !
    azot94 Friend
    #501428
    When I turn on error reporting
    Fatal error: Cannot redeclare class JViewLegacy in /home/www/jadrowe.pl/subdomains/www/libraries/legacy/view/legacy.php on line 798
    phong nam Friend
    #501456
    Hi azot94,
    Thank you for sharing this error reporting. The same issue was fixed with the solution at http://www.joomlart.com/forums/topic/jviewlegacy-error-after-updates/#post-476190
This topic contains 6 replies, has 2 voices, and was last updated by  phong nam 11 years, 5 months ago.
