Also another bug :
my both browsers : chrome and opera tells me that there is unsecure content, so comments are not displaid on secured browsers when in https
is this a way to solve that ?
tabs in admin not displaid when system jacomment plugin is on
Am I ok to take a backup of your site and test on my machine?
Paul
paulus1031
there are some infos I can not let be downloaded on that site.
I thought one of joomlart team could go inside and view the both issues
If it is not possible, i would create a new site to reproduce the issue
At the moment there are quite a few errors relating to
Uncaught ReferenceError: jQuery is not defined
Can you fix those and another team member can have a look without downloading a copy of the site
Cheers
Paul
It is solved by desabling ja_comment system plugin
If enabled :
template.js?2b9fced2814c5630ed4b6156a6e57178:200 Uncaught TypeError: Cannot read property 'click' of undefined
at HTMLDocument.<anonymous> (template.js?2b9fced2814c5630ed4b6156a6e57178:200)
at i (jquery.min.js?2b9fced2814c5630ed4b6156a6e57178:2)
at Object.fireWith [as resolveWith] (jquery.min.js?2b9fced2814c5630ed4b6156a6e57178:2)
at Function.ready (jquery.min.js?2b9fced2814c5630ed4b6156a6e57178:2)
at HTMLDocument.K (jquery.min.js?2b9fced2814c5630ed4b6156a6e57178:2)
should I do anything else ?
error displayed seems to come from the ja_comment plugin
another error when enabled :
template.js?2b9fced2814c5630ed4b6156a6e57178:184 Uncaught TypeError: emptyMenu.Jvisible is not a function
at HTMLAnchorElement.<anonymous> (template.js?2b9fced2814c5630ed4b6156a6e57178:184)
at HTMLAnchorElement.dispatch (jquery.min.js?2b9fced2814c5630ed4b6156a6e57178:3)
at HTMLAnchorElement.r.handle (jquery.min.js?2b9fced2814c5630ed4b6156a6e57178:3)
another problem, always on the same site, I tried to reload joomla by joomlaupdate component and it worked only with the plugin disabled
I just made a backup, you can go inside akeeba and download it to test on your server if needed
I tried on a test site on the same server, always the same issue.
Yes it does, thanks a lot
