- Edited
saguaros ok, I 've edited the fieds with ftp details too
Hi, you are right, it checks IP so it does not allows to proceed if the current ip address is not known.
web hosting is aruba.it
you should go into ftp section and add your ip address and save the data.
then it should allow to go into.
pls let me know
saguaros done, I've added the exceptions.
Pls let me know if it works for you now.
I do not know what else I could try...
Thx in advance
saguaros hi, have you any update? I noticed you modified something having effect in the virtuemart's products pages...
Pls keep me informed of any progress
Thx
Hi teitbite and Saguaros,
thank you for your effort and support.
Apparently it has ben improved, but it is just for the sidebar, but with many regressions, for what I found looking here and there.
At the same time when selecting AUSILI from the horizontal main-menu I should get immediately its SIDEBAR and AUSILI's Subcategories, instead I get SIDEBAR and the two main categories icons AUSILI and STANZEMULTISENSORIALI. When I select then AUSILI from the ICON in the main-body, I get what I was expecting with the first original selection.
Same happens with the other horizontal main-menu option STANZEMULTISENSORIALI, I get SIDEBAR and the two main categories icon AUSILI and STANZEMULTISENSORIALI. When I select then STANZEMULTISENSORIALI from the icon in main-body, I get what I was expecting with the first original selection of the horizontal STANZEMULTISENSORIALI.
What is worst is : if I want to select a product having no price, for example "PUNTAMENTO OCULARE" and "EASYeyes - dispositivo a puntamento oculare" I see it has been lost all the SKU and price details, instead I get a word ARRAY that I do not know where it comes from
Similarly if i go to select a product where the cost is present, I have something different from what I got before your intervention.
I attach two screenshots of the previous data
and
Last, in the home page, I have featured products, you see that they are not ordered, after the first row of 4 element in the second row I have three free position and only the last one is occupied, then the third row is again fully occupied..... so i would say there has been a regression. {for this same issue I asked for your support recently.. check discussion "products displays"}
I hope you have written down all the modifications you did, What I'd like is to recover the previous status and please explain me what you did, might be also with screen shots, so I can carefully read and understand what you did to get only the positive elements, without any regression, without any modification in important elements for my website.
I updated this file: /templates/gk_shop_and_buy/html/com_virtuemart/category/default.php
<?php if(!isset($iBrowseCol)): ?>
<div class="clear"></div>
</div> <!-- end browse-view -->
<?php endif ?>
at the end of file to fix the sidebar issue.
lorenzodf At the same time when selecting AUSILI from the horizontal main-menu I should get immediately its SIDEBAR and AUSILI's Subcategories, instead I get SIDEBAR and the two main categories icons AUSILI and STANZEMULTISENSORIALI. When I select then AUSILI from the ICON in the main-body, I get what I was expecting with the first original selection.
It's default behaviour of Virtuemart, if you assign that AUSILI menu item to a standard template of Joomla like Protostar, it will work with the same way.
With the 'array' text, there seems to be issue with override for detailed page in template, I've reported to the team for update on this also.
HI saguaros, thank you for your explanation.
LOCALLY : I tried locally to modify the file as you indicated /templates/gk_shop_and_buy/html/com_virtuemart/category/default.php and I got the sidebar to go as expected on the side of the pages instead that at the bottom.
ONLINE: To recover the order for featured products in the homepage in templates\gk_shop_and_buy\layouts\blocks I copied head.php as modified for your previous suggestion that I had locally.
The wrong file is named now head_191104_error_order-featured_homepage.php
ONLINE: To recover the codes in Virtuemart products in templates\gk_shop_and_buy\html\com_virtuemart\productdetails I copied default.php that I had locally.
The wrong file is named now default_191104_error_products_code.php
What still remains are the FEATURED Products (with title in English) at the bottom of the page if I select AUsILI or STaNZEMULTSENSORIALI from MAINMENU as already described above. I would not expct any FEATURED PRODUCTS in that position
THX
You can decide to show Featured products or not via Virtuemart Configuration >> Templates >> Shopfront settings: https://prnt.sc/pt2wog
HI,
thank you for all your support.
After the current Virtuemart update, also the last issue has been solved.
You can close this post.
