fabridelo Also, Kindly ensure that you have template version upgraded to latest version i.e.UBER version 2.1.8 as the same had been updated for various bug fixes
https://www.joomlart.com/updates/weekend-updates-7-joomla-templates-updated-jomsocial-major-release-and-more
UBER version 2.1.8
Map displaying problems in Uber App
Initial loading screen missing images
JA ACM - Hero Style 4 video doesn't play on chrome browser
Video player autoplay
ACM Module does not show position selection when edited on frontend.
Hello
I updated all but the problem remain
Any suggestion?
Best Regards
    Hi fabridelo
    Your video is working now
    For any reference please have a look HERE Specifically to the autoplay restrictions -
    Thanks a lot Pavit
    The link no work but the video work well
    Best Regards
      fabridelo The link no work but the video work well
      I don't quite understand - is the problem solved?
      Cheers
      Paul
      es but I do not understand how he solved it
      Best regards
        fabridelo As apparently seen, You seemed to have updated the template to latest version which should have fixed the relative issue 🙂
        16 days later
        Hi There,
        Can you enable our support team to view the site by unblocking UK, USA and Vietnam from your firewall
        I'm based in the UK and can not see the site
        Paul
        diegopmusic That could be happening?
        Could you please open a new discussion regarding your problem and add to your post a temp super user account for your backend so we can have a look at which problem is causing this ?
        https://cl.ly/3y3R0p24250G
        diegopmusic Hi, I have the same problem with Hero 4 and with the Guru videos, they do not do autoplay.
        In order to enable in addressing your relative issue being mentioned more appropriately, Kindly let us know about the following :
        1) Which browser can you see this relative issue in - firefox, chrome or safari browser ?
        2) Kindly confirm if you have updated the template version as stated earlier
        If still the issue persists after reviewing for (2) point, Please start a new topic/discussion for the relative query as the specific topic has been started by another member
        Also, Can you add your admin details in edit fields in the new topic started in order for us to take closer look
        For reference, You can follow thread post (5 point) procedure.
        pavit locked the discussion.
