andrewm57
Our developer is working on this, I will get back to you as soon as I get the solution.
Appreciate your patience on this.
I am running out of patience. My client has lost multiple sales due to this bug. You have detailed information down to the exact line of code. What's the hold up?
    andrewm57 It's quite different from the default file, our developer is working this, I will get back to you as soon as I got solution.
      andrewm57
      Could you increase your php memory_limit from 128 MB to 256MB? Megefilter need more memory to index all your products.
      andrewm57
      Now you just need index filter again, the price will be fine. Please check.
      P.S: Remember backup helper.php file.
      andrewm57
      Your problem was php memory too low.
      I also did optimize 2 things on your helper.php
      + because of your php memory limit, i have to turn off auto generate thumb for virtuemart product. check line 187
      + also your prices are rounded, so i made some changes on lines 219, 220, 222
