I have been trying since I purchased this in May. There is no way you can post on here. I fixed the registartion. The URL is http://anathletesperformance.com/index.php/online-training/jomsocial
MESSAGING AND REGISTRATION WILL NOT WORK.
I can not post anything on it.
How do you post on JomSocial? How do you Upload Pictures? How do you upload videos? Can I attact files in the accounts like an excel sheet or PDF file? If you can how?
Here is a screen shot of the Profile I see no way to be able to post messages or anything.
ammon2
Kindly Edit fields in first post and submit your site temp super user login to check the positing issue.
http://prntscr.com/vmk7l8
If the posting box showing with default Joomla templates, there issue with the template you are using not from JomSocial.
I am using the default joomla template
I do not understand what you are asking, I am sorry. I do not see edit fields at all.
The posting box has never shown up
ammon2
Kindly Edit fields option in first post of this thread
Submit your site super user login http://prntscr.com/vmkp63
Joomla default template is Protostar. WIthout login i am not able to check your site issues.
I went ahead and sent the info
ammon2
Message Issue : Your site does not have any member to send message, How can you send message to yourself?
Add some members and you will see option to send message.
About posting : This issue is not from JomSocial, its from the template you are using. I checked with default Joomla template Protostar and it worked fine http://prntscr.com/vml8vl Kindly contact the template provider for the JomSocial compatibility with their template.
