Ninja
I made a super user acc and refreshed the info post.
Ninja
Ninja
Thank you for your help. However the like and share buttons showed up they do not work properly.
End of share button text is cutted down and if I click on it get an error message.
So thanks for all but I give it up. This website will work without this facebook buttons.
Your installed Akeeba backup. Do I need this stuff or should I uninstall it?
pcMANiac1
I am not sure which backup you mean, as i have not installed anything.
About he button i can not see it on your site and the login is no longer working to test it.
http://prntscr.com/106e2mq
Ok I fixed login. But please leave turned on my css override because I need it. I do not like the genuine fonts and some other things.
pcMANiac1
It appear issue with your FB App id. I removed the ID and it working normal http://prntscr.com/106r0n9
