- Edited
...thanks Saguaros, do you need also FTP access?
Hello Saguaros,
...any news about the issue with sticky menu?
Thanks,
Lorenzo
Hi Lorenzo,
I'm checking with our developer on this, will keep you posted.
Hi Lorenzo,
Our developer investigated further on this and found out that on this EasyDiscuss page, they utilize JS to render the special layout for mobile so it's not possible to add class for scroll behaviour.
Could you pls also contact support of StackIdeas for further checking on this?
Hello Saguaros, here is the answer from Stackideas team:
From what I checked, that is the EasyDiscuss toolbar mmenu.js script that pushes the content into this div "mm-page mm-slideout" after the < body > tag.
May I know is it possible to adjust their Javascript to find the element if under this parent div (screenshot: https://take.ms/7jT6E )?
Because I did try to exclude some of the id or class element from the script, it seems like still can't make it work. (screenshot: https://take.ms/5qSfd ) All these div content is not under the "mm-page mm-slideout" div which injected from mmenu.js
noSelector:["#zen-wrap", ".zen-fixed", ".sb-slidebar"]
Or is there any important element that needs to exclude as well?
Hello Saguaros and thank you for your support,
… no I don't think Stackideas devs are working on the website, they were waiting for a response from me.
On my side I don't see any error in the console, on which page do you get this error?
Could you tell me which file has been modified to fix this issue on my local website?
Thanks again...
We updated this file: templates/buildr/tpls/blocks/scripts.php
You can compare to see the difference.
P/s: in your video here: http://u.pc.cd/xKe7 which simulator / site you used so you can test the mobile / tablet side by side like that?
... and I think the price is reasonable compared to other services you can find on the web ...
