saguaros
I updated the user name to dth and the password is listed in the secured fields. the original user name was dth-development
    I just verified the pass word. no caps or spaces. just the word.
      Saguaro,
      you have used the incorrect user name. I have made both active for you with the same password.
      cageman
        cageman I can login now.
        Could you tell me the field name that you have issue with?
        I just tested on your site with the field called: 'Are you planning to take an EVT Test?' as I can see it's required on frontend but in backend settings, the 'Required' fields are set to 'No':
          saguaros
          The field name is HYD2021 Settings are: Default: Yes; Profile: Yes;
          Under the event 2021 Hydraulic Training: Used for event: Both; Required: Yes; Group Registration: each member.
          That is why I am reporting as a bug. The field is not acting with the proper settings as expected.
          I'm on Holiday and have spotty internet coverage so don't worry if I do not respond for several days. Just happened to be in a town for a little bit right now.
            cageman
            I tried to register that event: 2021 Hydraulic Training
            I filled all fields but not select any option for the 'HYD2021' field and the site throws the error correctly:
            It seems report correctly. Could you check again?
            10 days later
            I am back. Yes, the check works correctly with the drop-down selection. But if you change the field to a radio field it will allow you to go past. I have an event named Test Event setup. The "Test the Cron" field is a radio style selection. See what results you get with it.
              cageman As I can see that you also set a default value but it seems that you added the wrong value.
              You should use the number associated for values, follow this order: 0 - 1 - 2
              If you want 'Not this one' is default selected value, you should put '2' into that field.
              Kindly check.
