rich-hi-rich
Kindly assign the module to Community menu item that is a Profile menu so it will show on the profile pages.
I also suggest you to use only one Jomsocial frontpage type menu.
Hello
It showed to profile menu now but it is coming in backend.
    rich-hi-rich
    rich-hi-rich It showed to profile menu now but it is coming in backend.
    Yes and the position is also for the Profile view so it will display on profile page.
    Hello
    I mean to say the module is behind cover photo
    also enabled profile feed top position which is also not coming
    I want to enable few module between actitivy stream is this possible. Is there any customization can be done or any filename if you can share will help me to check
      rich-hi-rich
      The module itself using own style code it is not from JS position.
      See this : http://prntscr.com/1wk3zoo It added height auto if you remove it will show fully. You can ask the module provider about the customization support as our support limited for own products only.
        ok, i will ask developer to fix . what about (2)latest arrival module on js_top_feed position. it is not visible only
          I have now assined it to single but still same issue
          Ninja The module itself using own style code it is not from JS position.
          Please check again it not from Jomsocial as the module is another extension and use own style and features. On JS there is only module position code like any position and module not using full height so kindly check with module provider for its style on this. As position already showing the module on front end.
          10 days later
          thanks
          so did you mean only we can apply jomsocial module on those positions
            rich-hi-rich
            You can apply any module on the positions, the output of the module depends on the module own style.
