How can active cache for masthead module? Why masthead haven't cache option?!
Its a big problem for lcp page:
https://pagespeed.web.dev
you can check any website with masthead module and artsy template LCP problem!
Joomla 5 has the desired option in menu management. Is it possible to use Joomla's own option in this format instead of this module, and can you announce the solution in the form of a few pieces of code and instructions?
    5 days later
    6 days later
    alirezamehrabun Hi
    You want to have cache option, you can update this file for module (unzip first): root/modules/mod_jamasthead/mod_jamasthead.xml
    mod-jamastheadxml.zip
    2kB
    7 months later
    hidden content
    8 days later
    I will forward to dev team for further update 🙂
