  • rooze Friend
    #156385
    I’m running Community Plus, using Mega Menu and have Virtuemart installed, with a dedicated SSL.
    When I move into the secure section, for example during checkout, the menu links pickup the https://
    So when I try to navigate away from the secure page, I get the “page displays non-secure information” error in IE.
    Also, I’ve noticed that the JA_Login module brings an error when running in secure – and I see in the source that the JS file is being called from http://
    I don’t care about the JA_Login for now, but I do need a fix for the first issue if anyone can help please.
    http://www.thenaturalshopper.com – if what I’m saying isn’t clear (just add a product, hit ‘checkout’ then use the nav buttons to move back into the site from the https://)
    Rooze
    The problem is from the Addthis button and like button , you can see:
    [PHP]
    <script type=”text/javascript” src=”http://s7.addthis.com/js/250/addthis_widget.js”></script>
    [/PHP]
    and:
    [PHP]
    <iframe src=”http://www.facebook.com/plugins/like.php?href=https://www.thenaturalshopper.com/&layout=standard&show_faces=true&wid
    [/PHP]
    The warning will appear when img, iframe, link tag calling http protocol. you try to check those extension having any option for detecting protocol or not?
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 14 years, 1 month ago.
