October 11, 2013 at 7:20 am #191300
Dear Sir
I want to display an image in the footer at position “footer-1” so that when i clicked on it a larger version of the image appears in a lightbox effect, how can i do this please?
I have try to install third-party plugins but seems there is a javascript conflict. can i use the modal effect of Ja Fubix to do this? and if yes what code should i use?
phong nam Friendphong nam
- May 2015
- 974 times in 888 posts
October 13, 2013 at 10:46 am #508835Hi 261284,
In this case, I suggest you to use our JA Popup plugin which allows you to display the images in popup view (lightbox popup). There are just 3 simple steps you need to do:
1. Install, enable the JA Popup plugin. Downloadable link at http://www.joomlart.com/forums/downloads.php?do=file&id=2111
2. Refer our JA Popup plugin’s userguide at http://joomlart.com/documentation/joomla-plugins/ja-popup-plugin
3. Create a Custom HTML module at one of footer position with the embed codes of JA Popup after reading the userguide above. Make sure you select Editor – None in Default Editore option of Global Configuration.
i.e: Here is a sample format of JA Popup embed codes:
{japopup type=”image” content=”images/stories/demo/gallery/gl-3.jpg” width=”700″ height=”380″ title=”Sample image”}<img src=”images/stories/demo/gallery/gl-3.jpg” width=”100″ alt=”Sample image” />{/japopup}
{japopup type=”image” content=”images/stories/demo/gallery/gl-4.jpg” width=”700″ height=”380″ title=”Sample image” }<img src=”images/stories/demo/gallery/gl-4.jpg” width=”100″ alt=”Sample image” />{/japopup}
Note: You can see the demo of popup images at http://joomla-templates.joomlart.com/ja_teline_iv/ at Photo Gallery module on the right sidebar.
October 14, 2013 at 7:50 am #508883Thanks sir. Works perfectly out of the box. Great plugin.
AuthorPostsViewing 3 posts - 1 through 3 (of 3 total)This topic contains 3 replies, has 2 voices, and was last updated by 261284 11 years, 1 month ago.
Using lightbox popup effect for images in footer
