miroslav-tunjic-gmail-com . Export sends ajax request to polulate records in . I saw your server give error "Error 429
Too many requests
The client has sent too many requests in a given time period.
Possible causes for this error message can be found in the easyname FAQ." . To over this please choose "Records processed per request: " to maximum value .
Minor updation in one file
    #1- Could you clarify this issue in more details so I can check?
    Fixed (code changes needed for new look form), One issue on your mapping is Dropdown field mapped to cb field of type "file" .
    #4 Birthday field is fixed . Issue is with date string validation with date formatting .
    #3 CSV export . Made change and details in my previous comment .
    "In addition, if I try to use the same email address in a group registration for each group member (often done in my client's use case), it prevents me from using it, saying: "Invalid field: Email". The user (registrant) is NOT logged in." . You have setting in DTregister config "general Tab" "Duplicate Registration Prevention:" Yes . So any duplicate email user/member not allowed .
     Issues related interface UI/UX had reported to team . Will look into it .
    	 "where is this redline coming from and what deos it does?"  It is joomla editor read more otion .
      If you're able to implement the patches and fixes you're making to DT Register into a maintenance release - no new features - just fixes - it would be very much appreciated.
      Please also address the issue I mentioned with the placement of the "Complete Group" button - it needs to be below the form and execute saving the member input and going on to the next step. Putting it on the left where the members are listed is unintuitive and confuses users - they fill in the form and click "Complete Group" thinking their entry will be recorded and the user is not added!
      As Miroslav says, this problem of introducing new bugs with every release is becoming detrimental to our businesses.
      Thank you,
      Ernie
      Hi all
      no.it is not fixed
      it is being populated, but not saved.
      You must go into the field and click to work, otherwise it will not save the registration.
      gslitt91
      no. it is not fixed
      gslitt91
      imagine, you are usig a dt register for a classes, workshops, ... and you need you user to upload their id every time again and again, and again, and again, and again.......
      you see... not cool
      if this is my mistake pls help me understand it and fix it, but i dont think so..
      Br
        CSV is not fixed
        i am having users in one event choosing some radio & checkbox fields (option 1, option 2, option 3, option 4...)
        and the choose different options somethimes 1,3,4 | somethimes 1,2,4...)
        but when exported, they all have all the option in the csv file.
        gslitt91
          you have removed the "event details article" feature, without telling anyone how did you solved and replaced it.
          so basically only you knew how it worked.
          could you pls update your documentation, it could save us a lot of headache
            Glad to hear that it's working now!
            another thing
            for free events there must be the possibility to remove the left column as this only brings in the confusion within the registration porocess if you are using dtreg for free events,
            - > you could insert this as a option in event configurations: "show/don't show cart for free events" or something like that, this would then simply show/not show Registrations cost and payments and like...
            another little thing
              gslitt91
              i am having some selection limits on fields, example [DIF21] but this seems not to work as i have 5 registrations for 4 places? and can add new users.... what am i missing
